Aircon condenser
Old 02-18-2002, 10:38 AM
UKPaul
UKPaul's Avatar
Default Aircon condenser
Hi,
I know nothing about aircon so if this a really dumb question then apologies:
My aircon has never worked (not much of a problem here) & if I push any of the little pushbike tyre valve type things in, nothing comes out (should there be pressure there?). The condenser is right in the way of what I'm working on (and needs a paint), so if I was to just disconnect it & mask up the ends of the feed & return pipes, would there be any potential problems?
TIA
Paul
Old 02-18-2002, 11:04 AM
FeedVaal
FeedVaal's Avatar
Default Re: Aircon condenser (UKPaul)
It will only be a problem if you leave it like that for an extended period. As long as the system is open, you're allowing moisture to enter which can eventually cause rust. I'd recommend you spend a few dollars for fittings to close the system up instead of taping it.
Old 02-18-2002, 11:38 AM
zwede
zwede's Avatar
Default Re: Aircon condenser (FeedVaal)
I wouldn't worry too much. My system was open for several years with the compressor out of the car before I bought it. When I revived the AC, I flushed it, replaced the valves (POA and expansion), replaced O-rings and the system has worked perfectly for 3 years now. With a few tweaks the vent temps are as cold as any modern car even with R134a.
To Aircon condenser
Quick Reply: Aircon condenser
