Leaf spring in!!! Just need the Stabalizer bar and the rear is done!!! pics inside
I got the leaf spring in today. Now, I just need my rear sway bar and I am all set in the back. I also installed the hard brake lines today and that was a huge PITA.
I installed this entire rear end alone with no helpers, and no electricity. I had never even changed the oil on a car before this project. Like James Browm says, I feel good!
:D
:D
Re: Leaf spring in!!! Just need the Stabalizer bar and the rear is done!!! pics inside (BAD-L88)
good to here
It's amazing what you can do when you are properly motivated. :cool:
:D
:D
C6 the C5 of tomorrow
WOW, thats a BIG F-in step!
Congratulations!
I've done My rear end and have worked on cars for years, it was pretty overwhelming!!!
Congratulations!
Re: Leaf spring in!!! Just need the Stabalizer bar and the rear is done!!! pics inside (427V8)
Great job. Here's a little tip. Don't torque down the 4 bolts which hold the spring till the car is back on the ground. If you do, this is the easiest way to break an ear off the rear cover. Then you'll hate yourself :) You want the weight on the spring to flatten it out before you tighten things. Chuck
