Rear end installed - picts
pictures as promised
Went together really easy with little problems - sway bar mounts were a little bit of a task but other than that it all pretty much fell together.
No smart struts but I do have the 1/2" thick spacer to lower the rear roll center, but I do have VB poly struts - offset trailing arms and bearings from Bairs - all stainless shims - new cotters - new poly pinion snubber etc.....
It started raining so we called it a day - all that is left is install brakes, shocks and bleed the system before pulling it out and driving it around the block before its off to the alignment shop.
[Modified by fauxrs, 12:30 PM 2/17/2002]
[Modified by fauxrs, 1:16 PM 2/17/2002]
Re: Rear end installed - picts (fauxrs)
Mmmmm perdy :). Glad to hear that everything went together ok. Did you have your existing rear end rebuilt or did you get a different one? What ratio? :cheers:
Re: Rear end installed - picts (bence13_33)
fauxrs: Looks really good! How long did the task take? I've done the same thing once before and I thought it was very time consuming, now I'm doing it for good :crazy: :yesnod: :lol: !
Re: Rear end installed - picts (groovyjay)
I did this last winter. There is great satisfaction when this job is done and you can drive it around the block for the first time. I was nervous. Listening to everything to make sure all was right. After several small trips, I have put many miles on the car. This winter the front suspension is getting done.
Congrats on a job well done.
I just came back in from the garage this moring and Have.....
installed calipers - L/R
installed rear shocks - L/R
set baseline camber
set baseline toe
filled diff w/ gear lube and posi additive
installed heat shield
connected parking brake cable (I'm a little worried about this as the offset arms make that cable want to really twist around)
so when I can get my friend back over we will bleed the brakes and set it back on the ground for a test drive. Gettin' close
heres another shot
