posi question and rear diff stamp question...
1. Where on my rear do I look for markings??
2. With both rear tires in the air, if I start spinning one tire(by hand) how long should it take before the other one starts spinning also?
Thanks.
I think my posi is nerfed...
Thanks.
Re: posi question and rear diff stamp question... (Metal_Wulf)
http://forums.corvetteforum.com/zerothread?id=223272
It's located near the differential support.
-Steve
-Steve
The tire should spin at the same time as the tire you are spinning. Almost as if they are locked. The numbers are on the bottom of the carrier near where the carrier and the cover meet.
Re: posi question and rear diff stamp question... (Gordonm)
Well me and a friend have determined that my clutch packs are really wore out...
still need to figure out what gears i've got...
Gordonm, thanks i'll check for the stamp in the light tomorrow.
