BigAlex and the twisted frontend
2nd Gear
Thanks for the quick replies! Mack-I'll try to post some pics asap. I should have been a little more specific in my description. I took a closer look today. This is what I found; the fender aligns with the drivers door quite well,the right side fender is slightly high at the door leading edge as well as at the rocker moulding,BOTH headlights hit the frontend at the rear of the opening,they require a little prying with the fingertips. The bonds inside the right doorjamb appear to be separated or they never actually bonded in the first place. I searched extensively for collision damage and there is none. It's as if someone replaced the front clip and just didn't push it down far enough. I can probably live with the door misalignment, but obviously the headlight problem sucks! Again thanks Mack,Norvil&Frank
