Beautiful Day To Burn Some Dinosaurs
Old 02-16-2002, 03:40 PM
Gordonm
Gordonm's Avatar
Default Beautiful Day To Burn Some Dinosaurs
Finally got around to changing the speedo gear from 4.10 to 3.70. Took the car on an hour drive. It is around 60 and sunny here today. This winter has been great. 1 small snow and it has been warm. I have not got many projects done due to the nice weather. I don't want to lay it up for any time. The trans still need fixing. Got a compliment from and old 56 Ford driver at the fuel pumps today. Just a nice day for a ride.
Old 02-16-2002, 03:47 PM
bence13_33
bence13_33's Avatar
Default Re: Beautiful Day To Burn Some Dinosaurs (Gordonm)
Gordon:
This winter has been pretty mild. It was about 50 degrees around here yesterday. So when do you plan to pull the Muncie?
Old 02-16-2002, 05:42 PM
Gordonm
Gordonm's Avatar
Default Re: Beautiful Day To Burn Some Dinosaurs (bence13_33)
When I get a blow shield. Don't want to have to pull it again. I'll do it all at once when I get one. It grinds going into 4th in the upper rpms. Normal cruise it is OK
Old 02-16-2002, 06:06 PM
427_Roadster
427_Roadster's Avatar
:cheers: :cheers:
Same here Gordon. Replaced 2 headlights, distributor cap and rotor(also had more chores lined up, just too nice out!) then drove for about an hour. Felt real good to be out in the Vette again! The top stayed up, but it won't be long now!
Tom
Old 02-16-2002, 06:13 PM
Flareside
Flareside's Avatar
Hey Gordon, if you need a destination for one of your cruises, stop by here! My car's been on jackstands all winter :cry (or is it spring?)
Old 02-16-2002, 06:37 PM
0Mike69@ECS
Former Vendor
Mike69@ECS's Avatar
Cruise-In III Veteran
Cruise-In V Veteran
Default Re: Beautiful Day To Burn Some Dinosaurs (Flareside)
:cry Mine is still apart!!!! Today was beautiful!~!!! :cheers: :cry
Old 02-16-2002, 06:44 PM
Eddie 70
Support Corvetteforum!
Eddie 70's Avatar
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: Beautiful Day To Burn Some Dinosaurs (Mike69)
Mine has been on jack stands now for about a month and will probably be there until around MAY!!!! I will be ready by the time warm weather gets here though. You guys make sure you take a good ride for me.
Old 02-16-2002, 06:50 PM
PRNDL
PRNDL's Avatar
Default Re: Beautiful Day To Burn Some Dinosaurs (Eddie 96)
Busy all day but managed to get out for a drive at 5!! :) It was nice! MJ
To Beautiful Day To Burn Some Dinosaurs
Quick Reply: Beautiful Day To Burn Some Dinosaurs
