I might be going to a Dyno on Saturday. Any advice?
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
I may be taking my 79 down to a dyno this weekend and I was wondering if anybody had any advice or tips.
I will also be getting A/F ratio tested and might change out the jets and/or rods. They charge $100/hr if you're tuning, so I may play around with timing if I'm not going too long. I've already got it optimized at 34 total mechanical all in by 2500RPM but I may play around to see if I get better results with different setups.
I plan on taking earplugs and a video camera.
Any other advice?
Any other advice?
Re: I might be going to a Dyno on Saturday. Any advice? (sharklover)
only advise i have is just have fun.
hope you learn alot. the air flow ratio test should tell you alot. play with the timing.
