ANGRY!!! Difficulty of Installing Dynomax Headers?!
I am pissed! The weather has been cold here in VA and I have not had the time to install my Dynamax Ceramacoat Headers. I find a local muffler shop who agrees they will install the headers, and install true duel exhaust to my Flowmasters. They will reuse the same mufflers, I provided the headers, I simply wanted them to install the headers, and run 2.5" pipes to my mufflers. They said, no problem and estimated the cost at $175.00. I figured that seemed fairly reasonable but after they delayed for 6 days getting parts, they call me today and give me an estimate of $608.00!!!! :mad :mad :mad I asked them why the inflated price and they tell me that to get to the bolts to remove the exhaust manifolds, they will have to remove the starter, etc. (I have already removed the A/C Compressor) I am too pissed at this point to reason with them and explain that isn't necessary. I told them I will just come pick up my Vette, remove the manifolds, and then maybe I'll ask them to install the pipes for me. (If only I could weld.....) I am a very passive person and this has pissed me off!
So, how difficult will it be for me to remove the manifolds? It shouldn't be that big of a task, should it?
Thanks for listening to me rant... I appreciate your advice.
Stephen
Stephen
Re: ANGRY!!! Difficulty of Installing Dynomax Headers?! (VolVette)
608 is kinda high in my opinion...Why not do the headers yourself..I did it is not that bad....then let them do the pipes from the headers back......
Easy drop the starter then pull the pipes then pull the manifolds and put on the headers. The headers are the easyest i have found yet you can hook up the wires on your starter from the top. You will love them when you get them on. I'm in Delaware and it's cold also just dress warm. :smash:
I haven't installed Headers yet but sounds to me like somebody want to screw the everlivin crap out of you. I wouldn't let em touch my ride with a q-tip. There has to be somewhere else you can get it welded. Sorry I can't help with your Question but damn thats high. :crazy: :crazy: :crazy: Good Luck
Its a pretty easy process, i JUST did this same thing not 2 days ago :)
If those manifolds have been on there for about 20 years, i would suggest
soaking them in some WD-40 for a couple days first. Mine came off pretty easily. You need to take off the starter (not very hard), and the exhaust will have to be dropped out to get it out of the way, then take the plug wires off, and remove the under-manifold wire looms, this is kind of a pain, the smaller bolts aren't all that easy to get too. Once you do that, make SURE to put the bolt back into the motor-mount ;) You need to remove the AC and bracket, as well as your alternator (both pretty easy) Now just unbolt those manifolds and pull them off, you may have to remove the spark plugs first to make it a bit easier.
Install:
The headers go in fairly simply, i only had to make slight modifications, i recommend a good gasket, i used a Felpro. The only mod i had to do was a little grinding on the steering box flange, and on the rag joint. For some reason it rubbed on the ceramic (good way to burn something up). I would suggest you have the headers "surfaced" to make sure the flanges are flat, it only cost me $10 at the local muffler shop. THe dynomax don't come packed all that well, and are known to be a bit out-of-shape.
So far i'm extremely happy with the setup :)
Oh, you may need new plug wires and looms, a good set of moroso and looms will be ~$80
Hope i answered your questions! :D
Install:
Re: ANGRY!!! Difficulty of Installing Dynomax Headers?! (Alwyn678)
Hi Stephen
You have to remember that the shop is probably charging you an hourly rate. I just installed mine last weekend and it took just about the entire day. First you have to remove the existing exhaust manifold and pipes up to the crossmember which in my case involved removing the AC compressor and alternator. You then have to drop the starter. If you have a stick shift you have to remove the Z bar and the cable that goes to the steering lock. You then have to install the headers from the bottom and try not to scratch them in the process. Once you got them up there you have to bolt them on. I know this sounds very simple but I had a hell of a time getting the bolts started with one hand while trying to hold the header with the other. Once you've done that you have to reinstall everything you took off. Now none of this is rocket science but it is time consuming and if you're being charged an hourly rate of around $50 it doesn't take long. You're best bet is to install the headers yourself and then have them connected to your existing exhaust. I just got a price locally of $150 to connect both sides and run a crossover pipe between the two in 2 1/2 inch aluminized steel. This includes labor. Hope this helps a little.
Ok why do you have to remove the starter? Does it need to be removed to navigate the new headers into place? I'm just about ready to buy my headers soon and I have allready removed my stock intake manifolds.
Re: ANGRY!!! Difficulty of Installing Dynomax Headers?! (Zane)
Do it yourself......I did! I don't think $608 is a completly outragous price though with the work involved, but doing it yourself is free!!!!! That's a savings of :rolleyes: :rolleyes: $608 dollars :D I know we all want to save $608 dollars :yesnod:
[Modified by Warp70, 8:27 PM 2/13/2002]
Re: ANGRY!!! Difficulty of Installing Dynomax Headers?! (Warp70)
Stephen
For a moment there it sounded like you were having difficulty installing. Mainly it is removing the ex. & spark plugs.
No problem driving to a shop w/ open headers. Several :cool: of us have done it. Just don't get on it around the cops, you can go to neutral & idle by.
:cool:
:cool:
Re: ANGRY!!! Difficulty of Installing Dynomax Headers?! (Ganey)
:cool:
:cool:
Matt
Re: ANGRY!!! Difficulty of Installing Dynomax Headers?! (Golden80)
:cool:
From a previous post you made you're speaking from experience, correct? :lol: (The post about the cop asking if you had mufflers.)
Matt
:cool:
Matt
Yes. Have never been stopped w/ open headers. :cool:
Thanks for your advice.
I picked my Vette up a few hours ago and drove home with open exhaust. I forgot to mention that I removed the catalytic converter and my exhaust was sounding awesome! I hope I can get some of the work done this weekend. I fear that the bolts will be a problem to remove.
By the way, I did drive by a cop when I was on my way home... Luckily I was not accelerating and had no problem making it home. :D
Stephen
Stephen
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Re: ANGRY!!! Difficulty of Installing Dynomax Headers?! (vettfixr)
Re: ANGRY!!! Difficulty of Installing Dynomax Headers?! (sharklover)
Hey VolVette -- what ever happened with that corvette in the Barn you were looking at? Always wondered how that story ended :)
I don't really see why you would have to pull the starter to take off the exhaust. I did it without pulling the starter, I can't see why you would need to.
Re: ANGRY!!! Difficulty of Installing Dynomax Headers?! (MikeC)
Dynomax recommends that you do it that way. I think the issue isn't getting the old exhaust out it's feeding the headers up from the bottom. It's a pretty tight fit with the headers vs. the original exhaust. Anyway, I followed their directions and it seemed the right way to do it.
