stall speed prob
stall speed prob
I have a 2000 stall in my car. After i changed motors and transmissions ( i pulled them and put them back as one ) Now my car does not like to sit still she pulls at 600 RPM in drive. I have curb idle set at 900-800 when i put her in gear she wants to shut off. Any guess what to check or do? :smash:
Re: stall speed prob (emsrescu)
Mmmm thats weird. With a higher stall u should get less drag on the engine at idle. What sort of TQ converter are u using? Converters also rely on engine rpm to pump fluid thru it which may change the flash rpm on diff engine combos. Still i think something must be gone inside the converter. They are pretty complex inside.
Re: stall speed prob (xrated)
It's a B&M Torkmaster 2000 I had no problems with her before the switch and now she is acting up. I only has maybe 100 hours on it.
This is a little confusing. Is this a new engine with a different cam perhaps? The problem you describe generally happens when a cam with lots of duration and tight lobe centers is installed. The engine doesn't develop sufficient idle torque to overcome the drag of the converter and tries to pull through traffic lights if you find an idle speed where it doesn't kill the engine or, it kills the engine when you put it in drive.
If this is the same engine with no other changes, you may have an ignition timing problem. Check you initial advance.
That depends. What is your idle vacuum? Have you tried adjusting the idle mixture? Does this engine have an aftermarket cam? Any other alterations?
