Time delay lights
Re: Time delay lights (emsrescu)
Sorry I can't help, cause I want to know this too. Mine acts up now and then, and I think my problem is weather related... I'll be watching this post.... :cheers: :cheers:
Why not bypass the timer if you know where it is. I did this on my Beretta for the very same reason. Having them time down after I have left the car is a waste.
On your 77 the timer is under the top dash pad, right above the speedo and tach. It is wired in line with the dash harness, and looks like a turn signal flasher canister, only a little larger. I hope someone can tell us both how to jump it out... cause I don't like the delay feature.
