How can I clean coolant off the engine?
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
I had blown a heater hose while driving and coolant got everywhere, including the freshly painted oil pan. Now I have ugly yellowish-green stains that will not come clean. Do I need to re-paint? Or will it clean up with something else?
Thanks,
Thanks,
Moderator
Re: How can I clean coolant off the engine? (sharklover)
I would use 'Simple Green' in hot water. You're gonna hafta use a rag on it though. Hook up your garden hose to a hot water source (hot water tank) and hose it off with low pressure. Should come squeeky clean. :cool:
Cruise-In V Veteran
Re: How can I clean coolant off the engine? (MasterDave)
I tried simple green but without hot water. I'll try again with the hot water and see if it works.
Thanks,
Avery
Thanks,
Avery
