1.52 roller tip rockers?
Old 02-10-2002, 06:11 PM
wes76
wes76's Avatar
Default 1.52 roller tip rockers?
I just finished my cam swap ,cs268 high energy, I re-installed the stamped factory rockers. Would I be better off with the 1.52 ratio, which comp cam calls for even though I have the 882 smog heads on. By the way, she runs very strong, but ther is always room for any improvement .
Bill :cheers: :cheers:
Old 02-10-2002, 06:14 PM
MasterDave
Moderator
MasterDave's Avatar
Default Re: 1.52 roller tip rockers? (wes76)
The stamped factory rockers are inaccurate at best. A set of aftermarket 1.52's is the way to go for accurate cam/valvetrain geometry. You might not notice the diff, but your engine will.
Old 02-10-2002, 08:56 PM
Ganey
Ganey's Avatar
Bill
Just enjoy it for now. A little better, you can add later.
:cheers:
Old 02-10-2002, 09:02 PM
wes76
wes76's Avatar
Default Re: 1.52 roller tip rockers? (Ganey)
My thoughts exactly... possibly when I get the second vette.
:crazy: :crazy: :cheers:
Old 02-11-2002, 08:07 AM
Ganey
Ganey's Avatar
Besides increasing lift from about 1.47 to 1.52 Comp roller tip will help reduce valve guide wear.
:cool:
Old 02-11-2002, 09:20 AM
ACLR810
ACLR810's Avatar
There is a great article on this very subject in the new issue of Vette magazine (I think it's Vette, could be Corvette Fever). They post some interesting dyno results from swapping racker arms.
To 1.52 roller tip rockers?
Quick Reply: 1.52 roller tip rockers?
