battery cable corrosion?
hi all -
while troubleshooting a different problem , I looked into the battery compartment
area and notice while corrosion on the cable. The corrosion is on the negative battery cable
but NOT at the end that touches the battery.
It is on the end that goes through the bottom of the compartment ....
hmmmm ? :(
hmmmm ? :(
Re: battery cable corrosion? (ksems)
Check to see if the insulation where it goes through the body is not cracked. If the insulation is cracked it will expose the wires to the enviroment and will cause corrosion.
It is on the end that goes through the bottom of the compartment..(
Good Luck, L8TER, Paul.
