Vacuum Diagram
Re: need 82 Vacuum Diagram... (rjs82vette)
Try this http://www.members.home.net/awsvette/vacuum.htm
VettePaul :seeya
VettePaul :seeya
Sorry about that rjs82vette. I've just checked it and it doesn't appear to be working. :mad It was on a few weeks back ! VettePaul.
http://www.docrebuild.com/
Try this. After you go into the site click on emissions hoses and thatll list all the vacuum pics...
Re: need 82 Vacuum Diagram... (Rich80)
Dr build doesnt have one for the 82... I am trying to find out the correct vacuum hose hook up for my canister..... I have looked at the vacuum diagram in my chiltons repair manual and it says that the canister only has two vacuum lines connected to it. The diagram I found online says it should have four line connected to it. and my only have three lines. There are only three places to connect lines to it..
I have one vacuum line coming from the intake goes to the PVC valve then conitures on to the canister... One line from the canister to the Gas tank..... and one line the goes to the vacuum canister switch then from the switch to the rear of the throttle body.... I am trying to find out if this is correct....
Soory cant spel...
Soory cant spel...
