Did manual LS-4's have a different crank?
I was reading throughsome old 73 articles and I believe the one from Super Chevy said that the manual 73 LS-4's had a forged crank with 2 bolt main caps and the auto's had a nodular iron crank. Does anybody know for sure if this is true or not? If it is, that's one less part I've got to worry about :D as far as the power levels I'm going for.
:cheers:
Pat Kunz
:cheers:
Pat Kunz
Re: Did manual LS-4's have a different crank? (73 LS-4)
Pat,
The manual trans LS4 used a forged steel crankshaft while the automatic trans LS4 use a nodular iron crankshaft. Both were 2-bolt mains.
This data is available on The '73 Spot. While you are there, I could use your vote on the Vette top 100, am about to fall out of the top 25. Or you could just click here to vote.
tom...
[Modified by Tom73, 11:52 PM 2/5/2002]
tom...
Re: Did manual LS-4's have a different crank? (Tom73)
I voted twice for ya Tom, I originally caught that info on your site then saw it on another so I thought I'd check into it. You wouldn't happen to have any of the casting numbers would ya?
Thanks
:cheers:
Pat Kunz
Thanks
:cheers:
Pat Kunz
tom...
Tom, I couldn't find a listing for the 3967414. I did find a listing for a 336782, 70-74 454 auto.
:cheers:
Pat Kunz
:cheers:
Pat Kunz
