Don't you hate the obvious things!
My speedo didn't work when I bought the car. The guy said it was a bad cable. No biggie. However I have a bunch of other stuff to do under the dash so I say to myself "I'll wait until I do all of the other stuff to fix the cable."
Well yesterday I'm in the garage and I get under the dask to take a look at what all I think I want to replace when I see the speedo. No cable attached. Hmmm he must have pulled the "bad" cable. So now I go under the car the see if the little gears are missing from the trans. Nope, there's a cable attched... So I go back under the dask and look around again. What do I find? the end of the speedo cable.
Plug it in, start up the car, back it out and BINGO! Speedo works!
Don't you hate the obvious stuff? :crazy:
Cruise-In IV Veteran
St. Jude Donor '03-'10
Re: Don't you hate the obvious things! (Monkeywrench)
sometimes the obvious stuff is nice, you just wish you'd checked it earlier. :D
No, I like the obvious stuff, because it's the only stuff I can fix! Did I tell you about the time I managed to get my car started after putting gas in the tank? :) MJ
Re: Don't you hate the obvious things! (Chris Fowler '80)
U should love it..Makes ur life Easier..Probably been unhooked for a long while to avoid putting any miles on the Car...Hmmmm that may be a bad thing actually
Re: Don't you hate the obvious things! (Alwyn678)
Re: Don't you hate the obvious things! (Warp70)
HEY! I finally understand what the term "origianl miles" means!! :)
Original miles are miles driven with the speedo hooked up.... MJ
