Could I cut my front srpings w/ a plasma cutter?!?
Simple yes or no, just wanna chop of an inch or 2 :jester
Re: Could I cut my front srpings w/ a plasma cutter?!? (dawebersZ06)
Yes you can cut them...
But heat changes the lb/inch on the spring, it makes them weaker... so dont cut them with heat... use a hacksaw
Location: Your Fighting Tigers of LSU. 2003 National Champs
Re: Could I cut my front srpings w/ a plasma cutter?!? (DCBStingray)
AAHHH! A question right up my alley...yes a plasma cutter would cut your car in half :D
Recommend a cutting wheel on an angle grinder. Plasme cutter can add too much heat messing with the tempering of the steel.
I say yes. Plasma doesn't generate all that much heat. It's not like any fuel torch, but if you have a plasma, you already know that. :D
Re: Could I cut my front srpings w/ a plasma cutter?!? (topless68)
I'd use a cut-off wheel.
