cc'd my cylinder heads
cc'd my cylinder heads, could this be correct?
I polished out the combustion chambers on my SR Torquer heads and then measured the chamber volume. The combustion chambers were advertised at 67cc. Measuring the chambers after I polished them, I had removed around 3.5 cc's!!!!!! Could I have possibly removed that much material? I removed barely enough material to lose the rough casting surface(or so I thought) which was pretty smooth to begin with. Is it possible that the advertised chamber volume could be off? I went ahead and assembled the engine, adjusting the gasket thickness for proper quench/compression but damn!
What do you guys think?
I measured the chamber volume by placing a piece of plexiglass over the chamber and injecting some alcohol in with a big horse needle(accurate to the tenth of a cc).
[Modified by Imabadman, 5:18 AM 2/1/2002]
Re: cc'd my cylinder heads, could this be correct? (Imabadman)
I'm not surprised at all. Be happy that you didn't measure a set of GM heads. Often, the GM heads are 86cc's rather than 76.
Re: cc'd my cylinder heads, could this be correct? (1979toy)
Wow, that really puts things into perspective. How much is the usual variation between chambers? Can compression differences cause engine damage?
Cruise-In VI Veteran
Cruise-In VII Veteran
My Vortecs were 61.2 to 62.5 cc's before I polished and unshrouded the exhaust valves. Checked out to 65-66 afterwards. Removed more than I thought! But I will still end up about 10 to 1 according to the calculations, with a .042 squelch area.
