Broke down and ordered 1.6 ratios today
Cruise-In VII Veteran
St. Jude Donor '07
When I picked out my cam I purposely chose a cam with mild lift to avoid a lope and vacuum signal problems. At only 434/454 it runs fine, but I think I can get alittle more air in the motor. So today I ordered a set of 1.6 ratios to increase the lift another .30 and hopefully my WOT rev to 5,500. Granted, I don't believe in the hp claims by the advertiser, I do believe it can only help in opening up the motor a little more.
Any thoughts?
Any thoughts?
Re: Broke down and ordered 1.6 ratios today (Budman78)
You may also have to grind down the oil drip tabs in the top of fyour valve covers to clear the new rockers.
Budman - just posted a similar question. Led me to another topic (linked off mine).
Interesting to read, particularty regarding the 1.6 ratio tests done by Car Craft.
http://forums.corvetteforum.com/zerothread?id=230355
