Weiland Stealth Intake
Will a Weiland Stealth Intake fit under a stock '69 small block hood. Does anyone have any experiece with this intake.
Re: Weiland Stealth Intake (Jester69Stingray)
I'm not sure on the fit but I do have one on my 70 Z28. It replaced a Torker2 and definitely has more throttle response off the bottom through mid-range. It may give up a bit on the topend but probably not much. It also helped give me a consistant idle w/ a pretty big solid lifter cam. Hope that helps a bit.
Re: Weiland Stealth Intake (Les)
Thats what i was looking for this will be replacing an original Torker so im guessing simmilar results.
The original torker is a pretty good manifold.So much that by popular demand Edelbrock is making it again.
Les is correct a dual plane with give better throttle response in most applications but first what cam,carb and compression do you have? What problems are you experiencing?Might need something other than a manifold.
The RPM will not fit with any air cleaner drop base or not and maintain sufficient carb to air cleaner top clearance for the carb to meter properly with your hood.You might get it under there and close the hood but overall carb performance will be less than optimum.Even with a KN top.IMO
The Stealth might .Never been there
The 74 Vette hood will give more clearance thn a 69-72 but here is a post I made from a couple years ago concernig manifold heights ect
My stock L-48 intake manifold measures 3" front height, 4.5" rear height. With a 3/4" spacer between the carb and the manifold it measures 3-3/4" front, 5-1/4" rear. With my large 18-1/2" diameter cowl induction type air cleaner assembly, the hood will close but it is too tight. It's hard on the air base seal and if a motor mount went out it wouldn't be good. I know that doesn't pertain to your '71 type hood, but it does establish some base measurements. If I had a after-market intake manifold on it that measured 3-3/4" front and 5-1/4", approximately, rear I would still have to use a drop base air filter assembly, in my opinion.
There are two ways to establish intake manifold height. One is to lay a straight edge on top of the carb pad and measure from the bottom of the straight edge to where the engine manifold meets the engine block. That gives you your front and rear heights. The other way is to take those established front and rear heights, add the two heights together, divide by two, and that gives you the overall height. In my opinion, overall height can be misleading, as it seems on Corvette hoods the clearance problem seems to be more in the front than the rear.
Here are some intake manifolds -- something to compare it with.
Holley part #300-36, idle to 7200, is a 180 degree manifold. Sorry no heights on this one but I believe it be similar to the LT1 manifold.
Holley part #300-48, 180 degree, 3.68 front, 5.02 rear, idle to 6000.
Weiand part #8004 without egr, action plus 180 degree, 3.50, 4.00, idle to 6000. Spreadbore
Weiand part #8000 with egr, action plus 180 degree is 3.75 front, 4.63 rear. Spreadbore
Weiand Stealth, 4.18 front, 4.50 rear. Squarebore
Weiand Team G, part #7525, with egr, open plenum, 3.50, 4.50, 2000 to 6500. Squarebore
Weiand advertises this in their catalog to fit Corvette 68-82.
Weiand Team G Power Ram, part #7530, open plenum, 2800 to 7200. Squarebore, 3.63 front, 4.56 rear.
Weiand part #7546, E-Celerator 1500 to 6000, open plenum, 4.36 front, 5.31 rear. Squarebore
Edelbrock Performer, idle to 5500, part #2101 non egr, 3.50, 4.60, 180 degree. Spreadbore
Edelbrock RPM and RPM Air Gap (Squarebore) and RPM Quadrajet (Spreadbore) all measure 4.20, 5.25.
[Modified by mountainmotor, 5:57 AM 2/1/2002]
Re: Weiland Stealth Intake (mountainmotor)
Cam is 222/222 duration at .050 and .447/.447 gross lift 114deg lobe separation, Holley 750 vacum secondary carb, and im not sure exactly what the compression will be guessing around 9.5 . This engine is not together yet but before when the intake was on the car it was a simmilar steup with a little more compression and about the same cam it had low vacum and not a whole lot of bottom end pull. I want to get some more bottom end but without giving up too much top end.
See pics at:
http://forums.corvetteforum.com/zerothread?id=219513
:flag
Re: Weiland Stealth Intake (Clink69)
You also don't have an air horn. That's why you can use the RPM intake. A carb with an air horn won't fit with the 68-72 base smallblock hood using the RPM intake. I trial fitted one with a Holley 3310 and the hood hit the air horn without an air cleaner on it.
Jester69Stingray. I've got the Weiand Stealth and 750 Edelbrock carb on my 79 with stock hood. Couldn't use the dual snorkel air cleaner though...... Will have to come up with a different base. JCL :cool: :cool: :chevy "Sidepipes are the way".
I've got a Weiand 3000 (whatever it is), and it appears to be of the same height and dimensions as the '70 LT-1 intake. It *barely* fits...i.e. under hard acceleration, the engine torquing can rub the air cleaner lid a little on the underside of the hood. This is with a 1 1/4" K&N drop base, the E-1650 (3") K&N filter, and the original chrome lid.
Re: Weiland Stealth Intake (gerry72)
I think a Holley carb Tunining manual would be a beneficial read about this subject of carb top to filter top clearance and the effects it has on the bowl vents and metering circuits :yesnod:
I have read about it many times
Think about this while we are at it.If the top of the carb to the top housing distance is 1.3 inches,how much breathing area is that? The 3 or 4 or even 5 inch filter used is thrown out of the picture! It would be 1.3 inches of height x the small diameter approx 6 inches" where the base drops close to the inside diameter,not the outside diameter.Is anyone following me?Also if the KN Extreme top is crammed against the hood,how much will it flow then?
Not nit picking really.Just a point to be made.Some follow build ups here on the forum and need to know the ins and the outs if someone else see's them :)
Senior Member since 1492
Clink69-- How difficult it to remove the air horn on that Holley? Does it simply unscrew or did you cut it off?
I have a Holley 3310 and for most of this year(I work slow) will remove my L-88 hood for prep and paint work. I'm going to put my stock hood back on so I won't have any Vette driving "down" time. I already know the Holley carb won't work with the air-horn attached.(hood won't close) But I haven't tried it with the L-88 dropped base. I was also thinking about that Pro-form Holley body that is available that has no air horn/choke.
Len :confused:
Len :confused:
Re: Weiland Stealth Intake (1970 Stingray)
Len :confused:
Len :confused:
Be sure not to go too far down, I left a little ridge on mine.
I suppose you don't have to remove top but at least remove the carb. :D
:flag
[Modified by Clink69, 1:34 PM 2/4/2002]
