What is the best method to remove old pin striping?
Have old pin stiping and a sb hood decal that is cracked, just the stick on decal. It looks terrible so would like to remove them. Also where is a good place to purchase the new replacement hood decal, similar to te black decal on the stinger hood but without the riser.
Re: What is the best method to remove old pin striping? (gdh)
A heat gun or hair dryer will make the decal and pin stripping come right off. Ecklers should have the new decals
Used a hair dryer in the past. I also believe they sell a decal remover that might help but it might also harm the paint.
Re: What is the best method to remove old pin striping? (ScubaJKD)
Go to your local paint and auto body supplier, and get a 3M pin stripe and decal eraser.
It is basically a large eraser disc that you put on a drill or similar device.
Unless you get VERY aggresive with it, they will not harm paint.
Just under $20 for the 3M, they may have an off brand for $10-$15.
Good Luck,
Good Luck,
Re: What is the best method to remove old pin striping? (82dukman)
I have found the hair dryer trick to be very reliable in the past. :cool: :cheers: :seeya ...........
Re: What is the best method to remove old pin striping? (SevenT1Shark)
go to the local coin op car wash and power wash them off..used to work at a car wash and when someone pissed me off i would get real close with the washer and take some of their pinstripe off...
