Any Naysayers before i order the Airgap manifold?
Re: Any Naysayers before i order the Airgap manifold? (Jenny)
I got one...love it. No clearance issues for me due to my hood..so I have the polished rpm air gap.... (bling bling) :D
Cruise-In IV Veteran
St. Jude Donor '03-'10
Go for it! :cheers:
What carb and air cleaner setup are you going to go with?
If I was going for the biggest bang for the buck I would buy the Weiand Stealth. No intakes that you order come with fittings or gaskets. So normally you have to get at least one large brass plug and the heater hose to manifold adapter. Various straight or 90 degree brass vacuum lines.
It seems to me that when a friend was going to put on a Edel RPM it needed to be drilled and tapped for an addition vacuum line and the Stealth already had it. So he went with Stealth and saved money also.
Edelbrock spends a lot of money advertising in the "Not Rod" magazines. It also gives away a lot of parts to "Not Rod" magazine editors to ensure its parts get used in projects. That's why its parts generally cost more than comparable pieces from other manufacturers and why the magazine articles always seem to make Edelbrock products look really, really good no matter how ho-hum it happens to be in reality.
Other companies have manufactured air gap style intakes for years. Edelbrock has simply done it with a low-rise intake and marketed the snot out of it like it's some kind of new thing.
Of course, I'm a diehard Weiand guy myself. Therefore I would have to second the vote for a Stealth on principle. That having been said, I'm sure you'll be happy with your new Edelbrock.
[Modified by The Dude, 10:16 AM 1/29/2002]
Re: Any Naysayers before i order the Airgap manifold? (The Dude)
Re: Any Naysayers before i order the Airgap manifold? (Alwyn678)
Doesn't Holley Own Weiand??????????
It's just a brand preference thing. You like spending a few cents more to get Coca-Cola. I prefer less-expensive Pepsi. It's all good. :cheers: Doesn't take away from my perception that Edelbrock parts cost more than comparable parts from other manufacturers.
[Modified by The Dude, 3:06 PM 1/29/2002]
Jenny-
I have just finished putting the RPM Air-Gap in, and everything fits under my stock '74 hood. Can't give you any performance numbers yet, but I am using a performer 600 carb, and I went with a drop base air cleaner and a 2 1/4" K&N filter. I'm going to try to get my roommates digital camera and post some pics soon. Hopefully when all the tuning is done, I'll be at about 390 HP (I've got Trick Flow 23 deg heads and a Comp Cams XE268).
Good luck. :cheers:
Good luck. :cheers:
Cruise-In III Veteran
Cruise-In V Veteran
Re: Any Naysayers before i order the Airgap manifold? (thebruce)
Jen,
I think you may be happier with the Performer RPM Air Gap for your 383 in the future as it will flow better at the RPM's you'll be seeing (depends on what valvetrain you select though), so you might as well buy the RPM Air Gap now and save some money later. However, if you're buying a different intake for the 383, then go with the Performer Air Gap for the semi-stock vette. It will take some ingenuity to get the RPM to fit under the hood but I got it to fit on my 79 and others have made it fit on their vettes too. Ask Tom what he thinks will be better too, he knows a lot more about this stuff than I do.
[Modified by sharklover, 1:06 PM 1/30/2002]
Re: Any Naysayers before i order the Airgap manifold? (sharklover)
Jen,
I have to agree with sharklover here. I have the RPM air gap in my 69 and after looking at all the possibilites thats what I chose for my 383. The performer might be somewhat restrictive, especially above 5K RPM. check out my install and the drop base I used:
http://forums.corvetteforum.com/zerothread?id=219513
:flag
I have the Airgap intake on my 81 and it runs great. It fitted up no problem but it was originally a very tight fit under the hood and I wasn`t happy running with such a thin filter. I felt it was restricting the airflow so I opted for a bit more radical solution that is not to everyones liking. Now you can get K&N filter tops and I would recommend using one with a low profile base and a 2" thick matching K&N filter especially if you move up to the bigger motor.
Click on the link to See it and Hear it Run.
http://www.smartgroups.com/vault/corvettes/Open%20Pipes
J.
[Modified by JHL81, 5:57 PM 1/30/2002]
[Modified by JHL81, 6:01 PM 1/30/2002]
J.
