Removing the dash mounted headlight switch in a 69?
I'm in the process of putting my dash back into my 69.
I would like to take out the headlight switch to fix the piece that say "lights" on it.
I know how to un-do the nut that holds the switch in place but how does the **** come off the shaft so I can pull the switch through the dash?
Re: Removing the dash mounted headlight switch in a 69? (James)
The **** and the shaft are a unit. The way you remove it is as follows. On the top side of the switch there is a little spring-loaded button. You must press it down and pull the shaft out of the switch. Then you can remove the nut and go from there.
Shannon
Shannon
Re: Removing the dash mounted headlight switch in a 69? (sb69coupe)
This is the best place to get answers to questions.
Thanks for the help sb69coupe.
:cheers:
:cheers:
When you pull the shaft out, do it CAREFULLY! It can get hung up on the dimmer wheel and if it's old the switch can be easily damaged.
Hans
Hans
