Trailing Arms in, have a question
I replaced my trailing arms from rebuilt ones from Bairs. Top notch units, quality work and they look good, too.
The thing I don't know is how tight the shims should be. I had to hammer the originals in one side. Will they loosen up with time, so the alignment can be done or what?
Can anyone recommend a good shop in southeastern ct or ri that knows how to align a vette properly? I got the camber right, but not the toe.
Thanks, Joe
[Modified by joe73vette, 7:26 PM 1/28/2002]
Thanks, Joe
Re: Trailing Arms in, have a question (joe73vette)
I think hammering them in is good. I did the same with mine. The alignment shop can reshim as needed. You want it really tight so there is no movement as it will change your toe in settings.
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23
Oldtimer
Re: Trailing Arms in, have a question (lbell101)
Don't the shims set against the metal sleeve that is in the front of the trailing arm where it attaches to the frame? I thought the shims are pined in against the metal sleeve as the bolt is tightened?
Re: Trailing Arms in, have a question (killain)
The shims go in between the trailing arm bushing and the inside of the frame pocket. The other end falls down into a notch that holds them there. Then a cotter key is put through them. I did tighten my bolt alot so that it would add pressure against the shims but I would think the tighter the shims are in there the less you would have to move the frame(with the bolt) to get it tight.
The shims are to be packed in as tight as possible. I got a lazer level for christmas and find it great for setting toe. Place it on the rotor and it must be a good rotor with the lug nuts tight and you can project the toe to the front rotor and come very close to getting it aligned right.
