Dashpad dilema
Dashpad dilema
Is there a good (read cheap) way to repair a dashpad. it doesn't matter if it is in or out of the car as it is the only thing left in the interior, but it would be nice to fix it cheaply so that it looks decent for a while. I am already spending money on carpet and seats and if the dash is too expensive to fix, it will start eating horsepower from the motor. In other words, the dash would not be fixed. The crack is maybe an 1/8" wide and and 1 1/2 in. long. On an oyster 1980
Received 1,468 Likes
Cruise-In II Veteran
Re: Dashpad dilema (chuckb01)
People say they get good results with a dashpad skin and crack repair kit. The trick is to repair the crack(s) first, then install the skin over the top of your repair work.
Beats the cost of a replacement dashpad!
Good luck.
Good luck.
Just fininshed mine ... not too bad ... except for the drilling of all the speaker holes, and the smoothing of the glue. Plan on spending a lot of time with a drill motor and a hair drier. But the end result is darn good if I do say so myself
I think the skin is 200.00, the adhesive is about 16, not sure n the foam ... got mine from CVA
Check out their NQP ( Not Quite Perfect) section, You might also get lucky
Re: Dashpad dilema (sray454)
sounds like a lot. i dont want to spend that much right now, so i may just live with it. has anybody tried that product on tv "liquid leather" or something? it is supposed to fix small cracks and tears "so you couldn't tell" it was always late at night and i was drunk so i never remember the name. anybody recognize it? :cheers:
[Modified by chuckb01, 8:03 PM 1/28/2002]
St. Jude Contributor
You can get the vinyl/leather repair kits at Wal Mart or most any autoparts store, but the results are likely going to be pretty disappointing (they were for me). The dash skins (this is not a dash pad, just a skin that goes over the existing pad and skin with adhesive) are not that expensive, and they come up quite often on ebay at about $90. If you're not trying for restoration, just for a decent looking dash, I'd go that way myself.
JB
'78SA
JB
'78SA
Re: Dashpad dilema (slide)
Don't see any leather skins, but do see the plastic snap/glue on covers. Is that what you have? Looks like it could work well.
The vinyl is all that's available, but then the original skin over the pad is vinyl as well. Slide--your page won't load for me.
JB
'78SA
JB
'78SA
