[mod] Brakes on power steering?
I can't find the post where someone did this. All I found was this post:
http://forums.corvetteforum.com/zerothread?id=222342
Is this the same thing? I would like to beef up my brakes down the road and am looking for a more consistent solution. Thanks!
Re: [mod] Brakes on power steering? (FroDaddy)
I am the guy who did this and keeps pushing it. My brakes are extremely powerful, very compact and cheap. They are almost a bolt in. When I say almost, try getting at the 4 bolts under the dash. I removed the old master cylinder and 4 bolts then used the 4 studs that came with the new hydraboost and installed them in the firewall like wheel studs. I now don't have to fight with those 4 bolts again. The rod also needs to be modified.
Re: [mod] Brakes on power steering? (norvalwilhelm)
norval you've been a great help to me and to others here on the forum. Thank you again for your help, your experience and knowledge have not gone unnoticed!
p.s. No, you can't have any pix :reddevil
