Installing front pace car spoilers
Old 01-28-2002, 09:51 AM
SteveA
SteveA's Avatar
Default Installing front pace car spoilers
Has anyone ever installed these?(the urethane ones). Center section is OK.. just can't seem to get a tight fit on the sides. Tried heating them a little and really pulling on them but there is still a gap between the fender and spoilers and they move around a lot. Any help appreciated. Thanks in advance.
Old 01-28-2002, 10:03 AM
MacA1979
Always Shiftin'
Support Corvetteforum!
MacA1979's Avatar
C5 of Year Finalist (stock) 2019
Default Re: Installing front pace car spoilers (SteveA)
Steve,
When I had my '79 I bought the one-piece fiberglass PC spoiler. I had the same problem with close fit. However, with the design of the one piece I was able to drill two extra holes around the radius of the wheel openings on both sides. Starting down low, I pulled the spoiler in tight and secured the spoiler with a screw. I continued this process until I had secured the top part of the spoiler. The picture below is the closest shot I have of the front spoiler, but you can see how tight it was. I don't know if this procedure will work for your urethane spoiler or no, but I thought I would pass this along anyway! Good Luck!! :cheers:
Old 01-28-2002, 10:43 AM
Chris@VetteFinders
Platinum Supporting Dealership
Chris@VetteFinders's Avatar
Where did you buy them from? Are the bolts not close enough to the top to pull them in?
Old 01-28-2002, 10:52 AM
SteveA
SteveA's Avatar
Default Re: Installing front pace car spoilers (Rhys)
Bought them from mid-america - & they have the bolts at the top. Granted the tolerances on every car is different, but don't fit the contour of the fender exactly unless you really pull up on them.
To Installing front pace car spoilers
Quick Reply: Installing front pace car spoilers
