15x10 rallyes
15x10 rallyes
I've decided that I am going to stick with te rallyes for now instead of springing for expensive alloys. it really is just an issue of money and time.
My question is this. Since i am installing a set of offset trailing arms in my rear end rebuild, and I can get a set of 15x10 wheel vintique rallyes. what back spacing shoul i use.
should I run them neutral(5") or something else. I will eventually be running 295/50-15 on the back which are 27" in diamter very closely matching my 255/60-15s that I run now. I will continue to run the 245/60-15 up front.
any opinions?
[Modified by fauxrs, 4:55 PM 1/26/2002]
any opinions?
Re: 15x10 rallyes (fauxrs)
I can just about run 5" of backspace on my car with stock trailing arms. I don't know much about the offset's but I would assume they give you another 1" of clearance like advertised. One thing to rmemeber though is that the frame comes before the t-arm, so that's your real limiting factor when it comes to thinking about bug meats out back.
