Roll Cage for 74 Vette question
Re: Roll Cage for 74 Vette question (mountainmotor)
I got my 4pt bar in kit form from Jegs. They also offer cages also. All the bars come in pieces and need to be fitted and welded together. After removing the interior and cutting access holes in the floor above the frame, I was able to tack the bars together outside the car and then place it in the car for fitting. My entire 4pt was welded outside the car and then placed in the car for the last time when welding to the frame. I also welded plates to the top of the frame to weld the roll bar to.
I can try and post pics later if interested. :)
[Modified by SmokedTires, 8:15 AM 1/25/2002]
Re: Roll Cage for 74 Vette question (ZD75blue)
:www.ioportracing.com
They have prices but not pictures. Check recent topics, someone posted pictures of their IOport bar that he just installed
This is who I originally talked to. They have great prices. I ended up going custom.
http://www.cachassisworks.com/home.htm
You'll be able to find my rollbar pics at
http://forums.corvetteforum.com/zerothread?id=226356
they show the rollbar in the car at different stages :) .
[Modified by SmokedTires, 8:00 PM 1/25/2002]
I've got a 4 point in my car from RJS. It stiffens things up a bit, but the mounting points are close enough together that it's more of a harness bar. Gkull has the real deal :cool:
Re: Roll Cage for 74 Vette question (Stingy74)
Thanks for the pics guys...
I had seen gkulls bar in another thread a while back... speakin of that did you ever get that seat problem worked out? where there wasnt enough of a view to the front or back or something? :confused:
