? on Grease (Zerk) fitting on Steering Control Valve
Does this thing get lubed up like the rest of the steering system?
Does it use the same grease as the rest of the steering/suspension?
Re: ? on Grease (Zerk) fitting on Steering Control Valve (Neo Fender)
This should get just a couple of pumgs of chassis grease and be good for a long time, don't over grease this zerk. Many members have greased, then removed the zerk, to avoid anywone else pumping too much grease in there. I think grease is just to 'hold' seal and keep dirt and water from getting in there.
I use Mobile 1 synthetic chassis grease on all of my suspension and this control valve.
