NEED YOUR ADVICE !!!!
My mechanic has recommended the following cam for my 1977, L-48. Automatic, car. Since I have been with the Forum longer than my mechanic, I would appreciate any feedback you may have. This is a Comp Cam.
Type RPM Range INT-DUR-EXH INT-060-EXH INT-LIFT-EXH LOBE C
dual energy
275 DEH 2000-6000 275 277 219 229 .462 .482 110 deg
Thanks
Larry
dual energy
Thanks
Larry
Re: NEED YOUR ADVICE !!!! (vettecor)
Larry,
Man, you're rolling on these projects :eek:
I'm not a cam expert at all (probably not even a cam novice), but from what I've read here I would think that cam is a little big for what you've got. I thought you had to have some aftermarket heads to use a 275. Also, I'm not sure what'll happen to your vacuum. I think I've read a couple of members getting recommendations directly from Comp Cams too; you may want to try that.
You'll get better answers than this I'm sure, but at least you're back to the top.
BTW, I thought you had a black Corvette :confused:
Thats a OK cam. What gear ratio do you have?
The reason I ask is there might be a better choice avaiable
[Modified by mountainmotor, 3:10 AM 1/24/2002]
CFOT Attention Whore
larry, what other mods do you have? IMHO, that cam is kinda steep for an otherwise stock l-48/auto. maybe with some better heads (or headwork), intake, exhaust and converter, that cam would be o.k. if the guts are stock, i'd say something in the 260-ish range is about the best your going to do.
