Starter getting to hot and it wount start....help please!
a friend of mine has a 75 with a 400 and headers in it. after driving it for a while the starter gets so hot the car wount start. He has a heat wrap on the starter which helps.....but not all the time. Will wraping the headers help?
Re: Starter getting to hot and it wount start....help please! (paul79)
I agree with paul79. Those mini starters are great. I broke the bolts on a GM high torque starter. I replaced the bolts with grade 8 and then sheared the gear off of the starter. I have had no problems with the mini starter.
Re: Starter getting to hot and it wount start....help please! (black_c-5)
Moving the solenoid to a remote (cooler) location usually helps. Summit has a kit. Its basically an old Ford type solenoid. Its a lot cheaper than a new high torque starter!
PN SUM-G1750, $24.95
The cure for heat soak.
GM remote mount starter solenoid
Your GM starter solenoid has a tough enough life without soaking up all that exhaust heat. Relocate it to a cooler spot with our Remote Mount Solenoid. You can mount it just about anywhere, and it can serve as a junction for accessories like our remote starter switch. Instructions included.
Mark
[Modified by mdsmith, 5:40 PM 1/23/2002]
Mark
If starter bushings are worn , starter will "DRAG or DRAW" big amps when they are hot .This my sound weird but Ive seen guys take the garden hose to there starters for a quick start
I have headers as well and after my engine build 4 years ago I rebuilt the starter as part of the job. I too had starting problems after driving on a hot day (plenty of those in Houston). I finally went to a parts store and got a rebuilt one which came with a small heat shield on the selenoid and have not had a problem since. You can probably get away with a rebuilt stock starter like I did.
[Modified by PatG, 8:18 PM 1/23/2002]
I like all of these solutions... especially relocating the solinoid... having that spot to connect the remote starter would be good...
I took the other route... I painted (after sandblast) the exhaust pipes with ceramic paint (BlackSatin from Techline Coatings) to keep heat off of everything including the solinoid. Very impressive product... its actually wierd to be able to touch the exhaust manifold before I can touch parts "attached" to the manifolds???
Re: Starter getting to hot and it wount start....help please! (Carl in LA)
I went through more starters on my big block (with headers) than I care to discuss... But a mini starter (I used a Powermaster), a heat shield, AND the remote selonoid (can use any ford selonoid) did the trick for me... I had to use all 3 of these before mine stopped crapping out.
Re: Starter getting to hot and it wount start....help please! (kenincanada)
The mini starter is the best fix though... enough torque in that to crank anything, no matter how hot.
Re: Starter getting to hot and it wount start....help please! (gerry c)
All these options which involve spraying water on the starter, couldn't this cause the metal to contract and crack? I know it's not a good thing to pump cold water into the engine block for that reason, doesn't the same apply to the starter?
-Steve
-Steve
Re: Starter getting to hot and it wount start....help please! (Pacin'California)
-Steve
-Steve
Thanks for all the feedback. I will relay all this info back to him. Except for the yahoo with the last negative remark :nonod: Must be a Pustang owner! :D
:flag
:flag
St. Jude Contributor
On the remote soliniod--that solved all my hot start problems instantly. Don't bother buying the kit--a ford solinoid is six bucks at Autozone and all else you need is a couple bucks worth of wire and something heavy guage (very heavy wire or a copper strip) to short the old solinoid.
JB
'78SA
