She's Home! Pic of the New Soft Top...
Finally got the car back after almost a month at the upholstery shop. Got a new soft top, full weatherstrip and new front carpets installed. The guy did a great job. Top is tight with no wrinkles, carpets looke great also. Had him install the new seatbelts for me while the seats were out.
Here's a snap of the top - I wish I took before pictures!
New top completely got rid of the 'old car' mildewy smell I used to have. :) Can also see out the back window!
Bad news is now I'll have to adjust the door glass on both sides for a better fit - which also means new handles and locks while I'm in there. He also found a brake fluid leak dripping into the interior from up under the pedal, where the plunger goes thru the firewall. :cry Guess I'll be busy come spring...
:cheers:
Tom
[Modified by 427_Roadster, 6:44 PM 1/23/2002]
:cheers:
Tom
Re: She's Home! Pic of the New Soft Top... (Alwyn678)
I would have taken interior shots of the carpets but it started to rain and I wanted to get it under cover. I"ll be taking interior shots of the 'before' shortly anyway when I swap in the T/T steering column.
[Checks to make sure wife is not looking over shoulder]
OK, the top was $275. Labor including pads new tack strip and grinding rust/repainting convertible frame was $545. 10 year guarantee against leaks. Not a job I would have tackled even at 2x that price.
Tom
Very nice...How much was the top to install??
Tom
Re: She's Home! Pic of the New Soft Top... (427_Roadster)
Tom
Tom
Do you have Power brakes?
How do you think can the brake fluid go on the inside???
...just wondering.....
The top looks great - my car will receive a glacier white one very soon!
I have it laying around for 2 months now.
We blasted and coated the frame first and now it only has to get warmer!
This is better for installing a top, its softer then will become wrinkle free and it looks more professional then.
Re: She's Home! Pic of the New Soft Top... (454Big)
Yeah, the top and the carpet needed to be done in a heated environment to mold correctly. I've even read that you should let them sit out in the sun for a while in summer months so they become more pliable.
:cheers:
Tom
The top looks great! That rear window looks like..... glass!
Price sounds very reasonable compared to other quotes i have heard. Especially for our part of the world.
I read somewhere... (??) to not even put up/take down soft top if temp is less than 45 degrees because of greater risk of tearing the top.
Looks like a real nice fit in back. Make sure it is not leaving a mark on the paint on the rear deck. MJ
