Sidemount headers for raised port BB - need recommendation
Big block with Brodix heads. Standard headers no longer fit, ports are higher and primarys interfere with spark plugs. I know Stahl has a drag race header with collectors at 90 degrees to the motor, about under the frame rail, but I am concerned about ground clearance. Does anybody have experience with something that fits?
Re: Sidemount headers for raised port BB - need recommendation (68427)
68427. Page MassVette, 69TTop502, Gdaina. I'm sure they can point you in the right direction. JCL :cool: :cool: :chevy
Well, I've been trying to figure this out for months, and it looks like there is no easy answer. At the moment, I'm planning to either buy off-the-shelf headers and modify them myself (if I stick with undercar exhaust), or go with the megabuck Stahl's for high ports (this is a $2000 solution by the time you're done!) Like you, I don't like the idea of a 3" pipe right under the frame rail. Have you seen Rolling Thunder's post about his Stahls? There's a post of his in the archive with pictures of the Stahls installed. He's given me a ton of advice about them. Great guy!
-Joe
-Joe
