Blemish repair after K36?
Help, I have a blemish...hehe
anyway..
I shot the ppg k36 primer this weekend and sat down (bent over) to sand it down with the 600 grit paper. Low and behold I find a nick and two pin holes. I don't know how I could have possibly missed them. I have sanded the complete car four times now. I tried sanding them out but they are too deep.
Should I sand down, fill and reprime? If so How do I add enough primer in that one spot to even out the surface?
I,m lost and don't want to make a move until I hear from the experts.
Thanks for your help.
Paint virgin
Terry
anyway..
Paint virgin
Terry
Re: Blemish repair after K36? (TerryN68)
Terry; For a few nicks and pin holes I would fill them with polyester putty. Let it cure, sand smooth, and spot prime the area. If you haven't been using a guide coat I would highly recommend it for checking imperfections. Good Luck, Craig :chevy
Re: Blemish repair after K36? (CF6873)
Thanks Craig,
I've been following the instructions Lars posted in the tech section. I am using a guide coat.
Thanks again!
T
Thanks again!
T
The Evercoat Plasticworks-Corvette Panel Advisive works great for these kind of items. Get it at you paint supply store.
Re: Blemish repair after K36? (Paul 75 L82)
3M (and I'm sure others as well) makes a product just for this application...filling pin-holes and scratches. It's a glazing putty (can't recall the precise name). I comes in a tube and requires no mixing. It is essentially a high-solids filling primer, so you spread it on with a body putty board and then sand it down. You don't need to re-prime over it since it is, again, a primer.
Re: Blemish repair after K36? (gerry72)
Gerry,
Thats the best plan I've heard yet.
I'll stop by the supply store and see what the have. You all have relieved my stress level again.
Thanks
T
Thanks
T
Terry; I am going to have to disagree with Gerry. I would not use a non catylized putty because they are lacquer based and may shrink. The 2 part putties don't cost anymore and will cure faster and not shrink. Also I would prime over the putty to insure that it is totally smooth and free of scratches. Good Luck, Craig :chevy
