electrical problem
electrical problem
Good morning,
I have an '82 CE.When I close the doors the dome courtesy light stays on -forever.Where should I begin to try to fix this problem?Thanking you in advance.
tankman :confused:
tankman :confused:
Re: electrical problem (tankman)
Check behind the glovebox for an orange "relay". It is the delay timer, that may be your problem. Also check the door light "rods" to make sure they are connected right and the ground is present.
