Replacing vacuum break assembly on 74 Q-jet
I ordered a new vacuum break assembly (choke pull-off) from GM and was suprised to see it did not come with the bracket that mounts it to the carb. The new assembly has a rectangular shaped mount, that locks into the factory bracket. My questions is how do I get the old one apart, does it just twist out or do I need to spread the bracket apart and insert the new part and try to squeeze the bracket back together.
Re: Replacing vacuum break assembly on 74 Q-jet (74ZZ430)
Yer, you got it! that's what you have to do, spread the bracket a little. Kinda like stuff that is crimped together. It is easy though. :yesnod:
