Sanding and going to put another coat of primer on Check out sig
Cruise-In IV Veteran
St. Jude Donor '03-'10
Re: Sanding and going to put another coat of primer on Check out sig (76 Red)
:cool:
It's starting to look like a vette again! :cheers:
Re: Sanding and going to put another coat of primer on Check out sig (Chris Fowler '80)
Sits pretty high in the front. Is there an engine in there? or does it just sit high....or maybe mine sits low....
Re: Sanding and going to put another coat of primer on Check out sig (flood)
Lookin good bob! I don't remember what nose and rear bumbers that you glassed on ? your old sig showed them filled in and it's amazing what a little paint does to making it look like it was made that way. :)
Flood
Yeah there is an engine in it. The wheel is turned a little to the right. and it does have taller springs than stock under it.
Paso
I put an 80 fiberglass font on it , It has the 80 rear plastic bumper on back. I will replace it with fiberglass in the future as well.
Bob
Paso
Bob
Re: Sanding and going to put another coat of primer on Check out sig (Warp70)
Looking Good, It's down hill from there. I can tell ya, what a feeling when your done, you'll be at all the car shows.
