Fasten Seatbelt Light/Buzzer stays on
The light/buzzer stays on all the time. Very annoying.
Any tips, advice, quick fixes for a 75 Vette? Thanks.
Re: Fasten Seatbelt Light/Buzzer stays on (1BadRat)
The seatbelt warning system is fairly lame. On mine the switches under both seats were very sensitive and if you so much as wiggled the buzzer would go off.
There are two ways to easily disable the buzzer. You can disconnect the plug connection on the inside of the seats next to the console which will also keep the dash light from coming on....or....go up behind the passenger side dash and disconnect the buzzer itself, but that won't kill the dash warning light.
To paraphase: If thy buzzers offend you cut them out.....
First thing I did was disconnect all the stupid buzzers, then bypass the light or remove the bulb. I bypassed the circuit.
[Modified by KenSny, 4:49 PM 1/21/2002]
