Anyone ever see French locks for header bolts?
Re: Anyone ever see French locks for header bolts? (Neo Fender)
Yes, I've used them in place of Stage-8. or ARP. You will probably need to file down the side that is near the header tube in order to fit the locks, but they work as good as "header bolts" I usually only bend one tab over each bolt head until I'm sure everything is torqued down properly, then I bend the other tab(s).
I use these, T D locking hedder bolts, they look and work great. part#8836 for sb 1-800-843-7836, tech line or 562-921-0404.give them a call. :cool: :smash:
