Someone please school me on C3 Steering Hardware
Mine is leaking like a sieve (probably the cylinder, but I haven't chased the leak down yet). What do I need to know before I drop any $$$ on this.
(1) Buy a kit or buy a rebuilt cylinder?
(2) replace hoses?
(3) Why did GM go with this arrangment? I haven't seen it on any other GM car.
(2) replace hoses?
Re: Someone please school me on C3 Steering Hardware (Neo Fender)
OK here goes... There are four hoses.. One of the large ones is from the pump to the control valve, the other is return. The two small ones that cross each other are cylinder retract and extend. The small ones, if you need to replace them can be a slight problem. What happen is that most(but not all) parts houses sell two identical hoses. That is wrong and they will not work. They will interfere with each other and create problems. There are two different hoses. So before you buy any of the small hoses just ask if the book shows two different ones.. If not find anouther source. You can buy a rebuilt cylinders and or control valves as well as the correct hoses from most any corvette supply house like Eckler's.. BTW GM did use that set-up in the 50's and early 60's. as did Ford on certain models.
Re: Someone please school me on C3 Steering Hardware (silvervetteman)
Just from watching on the forum, it is usually the control valve or pump that goes bad first, check that area. Spray the power steering components( control valve, pump, cylinder)down with brake cleaner, and blow off with compressed air. Then go for a short ride, hopefully this will help you find what is going bad.
Have Fun!
Have Fun!
Cruise-In VI Veteran
Cruise-In VII Veteran
Find the leaks first before you go changing things out. Get some degreaser, soak everything down, and then wash it off. Get all the grime off of everything.
Put it on stands and wipe everything down so it is dry and no grime or dirt to hide leaking parts.
Park it over a piece of cardboard and let it sit. Then look where it is dripping from. Cylinders will occasionally leak, mine does periodically, then stop, just a drip or two.
The place that usually leaks massive amounts is the PS control valve. They can be rebuilt with kits, or you can order a rebuilt one. There has been a lot of reported problems with rebuilt ones. In the last week or so I know I have read at least two threads on bad PS control valves.
Re: Someone please school me on C3 Steering Hardware (Smokehouse69)
change everything out...
change the valve.
change the hoses.
change the pump
change the cylinder.
:lol: :lol: :lol: :lol:
your gonnna have to do the hoses anyways..... might as well do everything else whilke your down there..
change the valve.
change the hoses.
change the pump
