Double Pulley for Alternator
Old 01-21-2002, 01:56 AM
StingRay327
StingRay327's Avatar
Default Double Pulley for Alternator
Where can I find a double pulley to put on my alternator? It sqeeks right now when i rev it up but I think If I put two belts on there, that should take care of it. There is an empty pulley on the fan that I would be able to put an extra belt on from the alternator.
Any suggestions on the sqeeking when I rev it up would be apprecaited also.
Thanks
Old 01-21-2002, 03:53 AM
rainman69
rainman69's Avatar
Default Re: Double Pulley for Alternator (StingRay327)
Make sure the belt tension is right. If it is...about 1/4" of play in the center of 6" of belt between two pulleys and about 1/2" play on 12" between...then do this:
Take a bar of Ivory, rub down all three sides of the v-belt that contact the pulleys, all the way around the belt. Should fix the squeak.
It could also be bearings, but try the first two fixes first. :smash:
Old 01-21-2002, 07:23 AM
Larry B.
Larry B.'s Avatar
I have had problems in the past with squeeling belts. I had a whole set from Auto Zone that were very noisey AND they also stretched beyound being able to adjust any more. I replaced them with GM one and they have been fine for a long time. :nonod:
[Modified by silvervetteman, 5:23 AM 1/21/2002]
Old 01-21-2002, 09:32 AM
KenSny
KenSny's Avatar
There's nothing to be gained by having 2 belts drive the alternator. The problem is elsewhere. Either the belt is loose, worn, the wrong V-size, or the alternator bearings are bad.
Old 01-21-2002, 11:51 AM
StingRay327
Thanks for the tips you guys. I'll give that all a try. I think maybe I might just get a new belt first and see what happens. Thanks again :D
Old 01-21-2002, 03:52 PM
Chris Breaux
Chris Breaux's Avatar
I haven't read the replies, but I've got a simple tip. Try "Top Cog" belts. Also check the alignment of the belt and tension. If it's too tight, it's just as big a problem as being too loose.
Old 01-21-2002, 06:29 PM
Cruzmeisters
Cruzmeisters's Avatar
Default Re: Double Pulley for Alternator (rainman69)
Ivory SOAP, no doubt ;) It sure is tough - at my age - chasing down an elephant for a tusk :yesnod: :yesnod: :yesnod: :cheers:
Cruz
Old 01-21-2002, 08:39 PM
rainman69
rainman69's Avatar
Default Re: Double Pulley for Alternator (Cruzmeisters)
Yeah, yeah, yeah...99 and 44/100 pure...
Of course it's not the elephant kind of ivory! :crazy: I mean, I probably have a GreenPeace hit out on my 'cause of all the pollutants my baby spews out of her tailpipes... :lol: :lol: :yesnod: :blueangel:
Lates. :blueangel:
Old 01-21-2002, 08:56 PM
PRNDL
PRNDL's Avatar
Double pulley...... been spending too much time helping my son study for his history midterm.... all I can think of is, "Archimedes" :rolleyes: :rolleyes: :rolleyes:
MJ
Old 01-22-2002, 12:52 AM
Cruzmeisters
Default Re: Double Pulley for Alternator (MNJack)
IF you get a double pulley and use two belts, MAKE SURE you ask parts supplier for a "matched set"; the "PinkLinc" utilizes double pulleys, and that's what I got when replacement time came. :)
Cruz
To Double Pulley for Alternator
Quick Reply: Double Pulley for Alternator
