@#$&% brake booster, tall valvel cover won't fit. What do I do?
Old 01-19-2002, 07:16 PM
69 N.O.X. RATT
69 N.O.X. RATT's Avatar
Location: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
Default @#$&% brake booster, tall valvel cover won't fit. What do I do?
I am running tall valve covers on my big block with a stud girdle. I have tried a few differant sets and the ones I like won't fit because of the booster. I finally have a set that almost fits (3/8 in.) I have the stock brake booster, do they make smaller ones, if so where would I get one. :chevy
Old 01-19-2002, 07:40 PM
8T1-7T9 BIONIC VETTE
8T1-7T9 BIONIC VETTE's Avatar
Default Re: @#$&% brake booster, tall valvel cover won't fit. What do I do? (69 N.O.X. RATT)
There's a system that eliminates the booster and makes lots of room for just your situation....your brakes work off your power steering...I just did the upgrade yesterday....and threw the booster in the trash....lots of room now and the brakes are awesome....pedal half inch to engage pads to rotors...any more and you're in full lockup. Aloha Cappy :seeya
ddn
ddn's Avatar
Go with Norval's hydraulic assist system.
Old 01-19-2002, 08:16 PM
73 LS-4
73 LS-4's Avatar
I got a set of tall valve covers to clear the booster on mine but it took a little bending and grinding to get it to work but they turned out great once done, don't know if I'd try it that way again though, hated grinding on a 200 dollar pair of valve covers :eek:
:cheers:
Pat Kunz
Old 01-19-2002, 08:39 PM
Default Re: @#$&% brake booster, tall valvel cover won't fit. What do I do? (ddn)
ddn,
Does Norval's have a web site?....I'm guessing this is the system I have in mine.....
Old 01-19-2002, 10:52 PM
69 N.O.X. RATT
Default Re: @#$&% brake booster, tall valvel cover won't fit. What do I do? (8T1-7T9 BIONIC VETTE)
Thanks for the replys. One problem, I don't have power steering, and have no intentions of putting it on. Isn't there a smaller booster I can use. :chevy
Old 01-20-2002, 12:53 PM
78Vette-SA
78Vette-SA's Avatar
Don't know if it will work in your case but I got a 7" booster and Dual MAster Cyclinder from Zigs Street Rods for $199.
http://www.zigsstreetrods.com/
To @#$&% brake booster, tall valvel cover won't fit. What do I do?
Quick Reply: @#$&% brake booster, tall valvel cover won't fit. What do I do?
