Fuel Pump Install ?
Fuel Pump Install ?
HIGuy's, I received my fuel pump today>GM< .Anything special I need to look out for during the install besides gas leaking from the lines.Is it as easy as it looks.Just plug in the lines,gasket, and tighten it up.Is there a certain way the lever lays on the cam.and yes I will change the oil.Thanks for your time ,Frank
