TH400/3.70 speedo gear help?
Old 01-16-2002, 10:35 AM
ORVette
ORVette's Avatar
Default TH400/3.70 speedo gear help?
I need to know which speedo gear to use with a TH400 and 3.70:1 gears. Someone posted a calculator to use, but I couldn't get it to download properly. Thanks.
Troy
Old 01-17-2002, 11:36 PM
ORVette
ORVette's Avatar
Default Re: TH400/3.70 speedo gear help? (ORVette)
Anybody? This driving off the tach is getting old.
Old 01-18-2002, 03:21 AM
Apeiron
Apeiron's Avatar
What size tires to you have?
Old 01-18-2002, 10:24 AM
norvalwilhelm
norvalwilhelm's Avatar
When I had the 400 and 4.11 gears I couldn't get the speedo right so I went to a local 4x4 place and bought a gear reducer. They have them in different ratios like 20% slower, 30% slower etc etc. They speed the speedo up for large tires. I took the thing apart and reversed the gears so it slowed the speedo down. I paid $5 for a used one. The speedo cabel in my 75 was 2 piece so I just installed it between the two lenghts. I got it right on.
Old 01-18-2002, 11:19 AM
Allan71
Allan71's Avatar
Default Re: TH400/3.70 speedo gear help? (norvalwilhelm)
I'm showing that you need driven gear #1362049 which is a 42 tooth, color code Green. The drive gear that goes with this is #8623310, but it looks like all ratios in 73 used that drive gear, so you should be able to just swap out the driven. Still available from your dealer, $8.60 list.
Norval, the book does show that using a 4.11 or lower ratio would require an adapter, and the the 3.70 is the lowest you can go without one.
Old 01-18-2002, 12:45 PM
andre77
andre77's Avatar
Default Re: TH400/3.70 speedo gear help? (Allan71)
Would I need the same with my set up? :confused:
Old 01-18-2002, 12:58 PM
gerry72
gerry72's Avatar
And while your at it, Allen, what's the driven gear number for a TH400 with a 3.55? I suppose that I could do the steps in my 3.08 to 3.55 switch, pull the driven gear, do the math and struggle with a bonehead kid behind the Chevy parts counter for the gear, but if you already got your book open...:)
Old 01-18-2002, 01:08 PM
Allan71
Allan71's Avatar
Default Re: TH400/3.70 speedo gear help? (gerry72)
Andre, yes it shows the same setup for the Turbo 350 with the 3.70 axle.
Gerry, your driven gear should be #1362048, a 40 tooth color code Black, still available same price as above.
Old 01-18-2002, 01:11 PM
gerry72
gerry72's Avatar
Thanks much, Allan! I always appreciate you guys who have those resources at your finger tips.
Old 01-18-2002, 01:12 PM
andre77
andre77's Avatar
:flag Thank you so much.
Old 01-18-2002, 01:56 PM
ORVette
ORVette's Avatar
Allan 71,
Many, many thanks sir!
Troy
Old 01-31-2002, 09:38 AM
gerry72
gerry72's Avatar
Just posting a follow-up to this old topic. For the THM400 driven gears, you may also have to replace your gear sleeve depending on the ratio your going to. The break is at 3.55. If you're going from a numerically lower ratio (like a 3.08 with a 42-tooth driven gear) to the 3.55 (40-tooth driven gear), you can keep your original sleeve, part # 1362293 which spans driven gear tooth counts of 40 through 45. If you are going from a 3.55 and numerically lower gear to anything above the 3.55 (like a 3.70) you will need to also replace your gear sleeve with the part # 1362294, which carries driven gears with 34 through 39 teeth.
Just something else to add to your research materials...
Edited to add: The sleeve costs about $21.00 and is, of course, still available over your Chevrolet parts counter.
[Modified by gerry72, 7:46 AM 1/31/2002]
Old 10-23-2015, 11:43 AM
c6silver
c6silver's Avatar
Good info
To TH400/3.70 speedo gear help?
Quick Reply: TH400/3.70 speedo gear help?
