Does a "72" L48 use a ballast or resistor wire to the coil?
I am not sure if I have either. When I check the voltage of the + wire after removing it from the coil, I get 12 volts.
The ORIGINAL and bestest
Toronto Events Coordinator
Re: Does a "72" L48 use a ballast or resistor wire to the coil? (KJL)
The factory wire is a resistor wire. I just replied to your other post about hooking up a MSD to this wire. The MSD instructions that come with it state that you can do this.
regards
Bruce
regards
Bruce
assuming your car is correct factory that is what you will measure without any loading, now with car running, you should measure about 8-9 volts or so, depending on dwell setting and idle speed, and alternator output....
yes that black lone wire that has a certain springy-ness to it, is actually steel wire in the harness and it's giving correct resistance as part of it's function....another wire goes down to the starter, and will supply a full battery voltage during starting for a temporarily hotter spark....but if that is allowed to remain on the coil + for very long, it will burn up the points/coil...
GENE
GENE
You will get 12V (or more depending on battery voltage) at the wire when it is disconnected because you need to have current flowing through the resistor to get a voltage drop. Measure the voltage with the wire attached to the coil and the points closed and it should drop a bit. I don't know what to expect, but I would guess it will probably be under 10V.
Gary
