Horn Button & Headlight Knob removal
Horn Button & Headlight **** removal
Hello,
This seems like a dumb question, how do you remove the Horn Button and Headlight **** without breaking anything ???????
Sometimes I do not know my own strenght.
Bill
Bill
Re: Horn Button & Headlight **** removal (Bill Hanna)
The horn button just pulls off with enough pressure. The H/L ****/shaft removal requires the LH dash pad to be removed for access to the H/L switch. Once you have access, depress the little spring loaded pin on top of the switch while pulling on the **** to remove it.
Mark
Mark
Re: Horn Button & Headlight **** removal (mdsmith)
Mark
Mark
If you cant get to it - then the dash pad must be removed.
St. Jude Donor '07
I don't think you should try pulling the headlight switch out. Awhile ago I applied a little too much pull and ended up pulling it out completely. And then it wouldn't work. Lights would come on, just wouldn't come up. I think I had to pay a mechanic to remove the dash to replace it.
