change from Manual choke to electric What would I need
I am looking into changing from my Edelbrock 1405 Manual choke carb to a Holley 650 with electric choke. My car had a quadro jet with a temp choke originally. What would I need to make this work??
Thanks
Bob
Thanks
Bob
Re: change from Manual choke to electric What would I need (76 Red)
If the Holly has the electronci choke unit on it all you would have to do is to run a wire to a constant hot. I used the positave side of the alternator for my Edelbrock.
JoeB
JoeB
Re: change from Manual choke to electric What would I need (woodworkr)
Thanks Woodworkr
I did not think it was going to be a big issue, but I was not sure..
Thanks
Bob
Thanks
Bob
You should actually have it hooked to 12 volt "keyed " power so you only have 12 volts going to the choke when you have the igntion turned on. on th Hei some people tap it at the distributor. :)
Re: change from Manual choke to electric What would I need (paso)
Thanks paso
I am planning on changing my distributer also. I`m going to go with a performance HEI. Put a dominator intake on also. This Edelbrock I can`t get tuned in. It probably just needs rebuild and jetted.
Thanks
Bob
Thanks
Bob
I'm going to change carbs soon also. Aren't there issues with tapping in at the distributor? How much does the choke draw? Does anyone know if there's any other readiliy available locations?
thanks
thanks
The ORIGINAL and bestest
Toronto Events Coordinator
Re: change from Manual choke to electric What would I need (Frank75)
On my car, a '72, I have an anti-run on solenoid for the throttle linkage that has 12v keyed power, and thats where I tapped into.
Bruce
Bruce
It's a little more work, but when I did an electric choke on a car I owned, I put in an oil pressure switch and ran the hot lead through that switch to the choke. That way, if you turn on your key and leave it on for a few minutes without starting the car, you still have choke. If you wire directly to switched 12V, anytime the key is on it will be heating your choke. It's not too hard to put in a T at your oil pressure sending unit and put in a switch.
