What should I look for when buying a 68-70 Vette?
I was hoping you guys could give me some insight as to what to look for when I go to look at any C3s, as far as what are common problems, etc.
Thanks,
Chris
Thanks,
Chris
C6 the C5 of tomorrow
Re: What should I look for when buying a 68-70 Vette? (DngrZne)
Look around the forum first, there are some fine machines for sale here...
Otherwise,
Look at the frame, right in front of the rear wheels.
Look at the car on a level spot and make sure it sits nice
Matching engine /trans /Diff numbers
Seat belts! ( damn expensive!)
Otherwise,
Chris
No real common problems except brake calipers leaking, many have already been replaced w/ the fix- SS sleeved calipers. Some may say vac. leaks- check headlight opening & wiper door opening. 68 has some unusual parts as first yr. & is similar mostly to 69. 70-72 are very similar.
PS 73 has some advantages that shouldn't be overlooked.
:cool:
:cool:
Look around the windshield. They had a tendancy to leak. If you look through the windshield along the side pillars you might
see some rust along the windshield if it has been leaking.
Chuck W.
Red69L68
Chuck W.
Red69L68
Look for frame rust where the first poster suggested to look. They all rust there, some so bad you need to weld patch panels to frame.
Second, look for any evidence of brake caliper leaking. Ask if the calipers have been replaced with stainless steel sleeved ones. YOu'll end up there for sure, so hopefully they've already been done.
Third, I'd ask about rear wheel bearings. If they have not been done, read some posts here about them, as they can be expensive. Loose bearings can cause rotor run out, which pumps air into the brakes, and you have brake problems. If you test drive, and hear a squeek, squeek at very slow speed, good indicator that rotors are running out and pumping the caliper pistons a bit. Not good news.
Check the radiator closely, as an aluminum rad can run about a grand US, aftermarket repos cheaper, but still big bucks.
Other than that, I've owned my 70 small block for 25 years and love the hobby.
Re: What should I look for when buying a 68-70 Vette? (bhawk)
Make sure if you're really interested in a particular C3 that you PUT IT UP ON A LIFT and check out the frame for rust before closing the deal. You'll never get a good enough look underneath without the lift.
C3s are notorious for rust in the side rails, rear wheelwell kickup & trailing arms. The frame rusts from the inside out so you may need to use a pick or small screwdriver to reveal trouble spots. I haven't seen many without SOME internal and/or fairly significant surface rust. While almost any frame except the worst cases are fixable, I'd recommend staying away from those that are so bad you can perforate the metal by hand.
Mark
[Modified by mdsmith, 1:16 AM 1/16/2002]
Mark
Real good advice from everyone here. I would just throw in check the passenger carpets for moisture/antifreeze. Could indicate that the heater core is shot. If you're looking at a car with AC, you'll need to take out most of the interior to replace the unit. If the car has shutoff valves on the heater hoses, make sure to run the engine with the valves open before checking. Not as major as the other checks listed here, but could be a deal breaker because of the PITA factor.
Good luck :cheers:
-Tom
Good luck :cheers:
-Tom
Re: What should I look for when buying a 68-70 Vette? (Eric 70)
You should look for MY CAR!!!! And bring a cashier's check for $19,000
Also I would seriously look at a southern car. Everytime I go to California or other southern states I am amazed at how rust free the old cars are!
I mean I see mid '60's cars with paint on the frame! :eek:
Go south!
Go south!
Location: WANTED: '68 rear valance with b/u light assemblies IM, e-mail, or PM me here. Thanks!
Try to hookup with someone in your area that has restored a c3 and take him/her with you to look at any cars you are interested in. Personally, I’d advise you to only consider restored cars or pampered survivors with less then 40K miles.
This is the route I took and I’m glad I did. I can’t imagine what this restoration would be costing me if I had to replace some of the parts that are known to need repair or replacing... like the frame, windshield pillars, headlight components, wiper door components, or glass.
If you goto http://www.corvettefaq.com in the MISC section there is a link to 3 articles on what to look for when buying a C3. good luck!
-terry
-terry
Re: What should I look for when buying a 68-70 Vette? (427V8)
Also I would seriously look at a southern car. Everytime I go to California or other southern states I am amazed at how rust free the old cars are! I mean I see mid '60's cars with paint on the frame! :eek: Go south!
Mark
