Oxy - Acet on exhaust?
Okay, I'm a bit miffed right now. I've had bad experience with shops making poor welds on exhaust with their mig welders, so I thought I'd just use an oxy-acet I borrowed from a friend. I've welded before, but am by no means an expert. (This is actually for my S10, but if it works out, I'm going to redo my Corvette exhaust with 2 1/2 pipe sometime this year myself.) So I took the whole muffler/tailpipe assembly out and cut off the sections of pipe I need to reuse with the new muffler. I expanded the muffler intake side just a bit so the old section of pipe would slide in. I cleaned both sections of pipe with a wire wheel before mating them up. Slipped the pipe in the muffler and it was a nice tight fit. Setup the welder and tried a #2 tip. Seemed too big, so I went to a 00 tip. Seemed like it was perhaps a bit small, but may work. I figured I wouldn't need any filler material since I had a nice overlapping section, so I went to work. The metal on the muffler would melt as expected, but the exhaust pipe section would never pool and would eventually just blow through. What gives? Am I just too unskilled, or is there really a good reason not to use oxy-acet? Perhaps filler would help, but I can't see how since I couldn't pool the exhaust pipe metal?
TIA,
-dath
TIA,
-dath
Re: Oxy - Acet on exhaust? (dath)
Your problem is usually caused by a coating on the pipe ,, and you are right if you get it all right the weld will be fine . I have mig ,tig,& oxy/acet and use the all at different time and applications . As always there was a lot of kick azz stuff built before mig or tig !! keep the faith :cool:
Re: Oxy - Acet on exhaust? (ram82fire)
Thanks for the sanity check! I was sure it could be done :yesnod:
-dath
Re: Oxy - Acet on exhaust? (oger)
They used Oxy-Acet on exhaust for a long time before migs became the thing. Migs are easier not better.
-dath
Re: Oxy - Acet on exhaust? (ddn)
I cut the exhaust off my '68 with Oxy-Acet :D
